Help: o2 Sensor will NOT come out
phantom Offline
i can not get this thing out. Tried everything, PB blaster, WD 40, Warming the car up and trying to take it out after i turn it off.... but no luck...And the o2 is whats causing my car to run so terribly. Anone have this problem? How can i get this thing out...everytime i put my full strength into truning the socket wrench, the O2 puller slips on the O2, and i dont want to round it off....?????
Well, if i beat you when i was stock, what would happen now?
left right left...the perfect shift...maybe i should call cadience when i bang the gears....
Matt S Offline
I've never used an offical O2 puller so I don't know what that is. I used a 6 point deep socket, and cut the wires right at the sensor so the socket would fit over it. Some propane torch heat, and actually tightening it a bit, then loosening it over and over got it off. The ultimate cauase was years of carbon baked on the threads. The 12 point deep socket I started with would not grab well enough.
Sold it Sad*
phantom Offline
what size is close to a 7/8" deep socket....maybe ill try that idea
JT Offline
o2 sockets that i seen are just a deep socket with a portion of the side slit so that the o2 wire can still remain. The ones i've seen tend to be quite weak, due to this design which gives less of a grip on the sensor itself.
SteveX82 Offline
O2 sensor sockets suck. Why not use the closed end of a 7/8" combination wrench? If need be, you can attach the closed end of another wrench (a 1" wrench should work) to the open end of the 7/8's one for leverage.
Glenn 88TC Offline
When you put the new o2 sensor in put some Anti-seize on the threads.
NO TC and NO headaches.
Thndrchckn420 Offline
Use a pipe wrench. It will either turn the O2 sensor out or turn your motor sideways. Its the only thing I could find to get the EGR tube off, should work like a charm on the O2 sensor.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
Joe F Offline
I found that a quick, hard jolt like hitting the (well seated) box wrench with a hammer broke mine loose just fine. That's also how I removed the EGR fitting from the E6.
Prior to doing that I soaked the fitting with WD-40 and warmed it up a bit by running the engine for a few minutes.
Alternatively, if you can get an impact gun in there it'll most likely come right out.
Good luck.
Joe F.
JR's Place - My 87 TC
= If factual statements hurt your feelings then adjust your view of reality =
Hurff Offline
Hopefully you get this before...
IMHO, you need to have the exhaust warm/hot *before* attempting removal. I have pulled a number of them from older cars, and when the manifolds/pipes were cold.... ended up stripping out threads (especially when I have done most of the techniques mentioned above and nothing moved).
Good Luck
Steve
1987 TC - RIP
Specifically, how do you know you need an 02? I been off line for a few days so if you already answered this in a prior post, my apologies, I'm working my way down the list
