motormenace
Jun 2001
Timonium, MD
I want to do a 3G swap this summer on my 86. I was wondering if anyone has used a V belt pulley on the 3G without out any problems?
Also, NO, I'm not planning on doing a serpentine belt swap do to the fact that I have all of the Esslinger Underdrive Pullies, Water Pump, and Wide Belt Cam Kit on the motor.
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
...so you have a V8...isn't that cute...
mfpmax
Jul 2004
Rockledge, FL
Shouldn't be a problem at all.
Keith Nubel
Liberty Township, OH
I installed a new 3G with the 2 V belt set up on my 85. Everything bolted right up.
1985 TC
turbobird63
Jan 2003
Telford, PA
I did as well, got it from PA Performance.
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
BlackTurboBird
Oct 2004
New Jersey
anybody no where the (black and white) wire goes from the altenator...tech faq says "the black and white wire goes to the S terminal on the regulater...where is the regulator and how do i know where the S terminal is...
