Littlehoe
Sep 2013
saskatchewan, Canada
10-05-2013, 01:20 AM
(This post was last modified: 10-14-2013, 04:14 AM by Littlehoe.)
Ok so I have the timing right, new cap rotor plugs. Car will idle with iac unplugged set idle, and tps. Plug in iac and the rpms drop and the car stumbles and dies. If I crank up the idle stop the car will idle fine at 1300 rpm and up. What should I check next?
1987 Turbo Coupe, Auto and running... Yippeee
boosted chicken
Jan 2006
Odessa, Texas
How old/gunked up is the IAC? They are pretty picky about being able to move freely inside.
88 TC#1 Boport stg 3 alum dport head, PT6466, Boport header, CP pistons, Crower rods, MS2xtra
goldwing
Aug 2009
North Carolina
10-05-2013, 02:39 AM
(This post was last modified: 10-05-2013, 02:41 AM by goldwing.)
I sprayed carb cleaner in mine then worked the spring a few times. I also spray cleaner in the little port on the intake.
I had to do this twice in a 3-4K miles period one time. Its been working perfect the last 7-8K miles.
T.C:87 5 speed
Littlehoe
Sep 2013
I have had it off and cleaned it out about 3 times now. it moves freely inside. Unless the motor part of it is hooched.
Littlehoe
Sep 2013
well it runs, Went out for a drive, anything off idle is great, nice and smooth, lots of power, making good boost. but when I come to a stop it runs rough, sounds like it is missing a bit on idle... it even stalls from time to time when it is sitting on idle. But there are no codes at all, no check engine light. I really don't know...
Could it be an egr?
Sounds like an air or vacuum leak which could include the EGR if it's dirty enough to be holding it partially open. The EGR does not normally open at idle. If you can put a vacuum gauge on it you should see 18-22" at warm idle. Less than that would indicate a leak. Start looking for cracked vacuum lines or disconnected lines.
w60
Dec 2011
Birmingham, AL
w60
is there a diode in the IAC? If the diode is bad will the IAC function correctly? Not trying to hijack the thread, I've read that there is a diode and wonder if there really is one and what happens if it is bad.
Diode is in the harness. Its there to protect the EEC from the inductive kickback voltages generated as the IAC pulses on/off. (IAC is a PWM modulated solenoid). Open diode just puts EEC at risk of damage, shorted diode = no IAC function at all. Partly shorted diode could cause idle problems I suppose.
Dan S
Jan 2003
Harrisburg, PA
+1 on Pete's comments above.
Did you go through the steps in this write up?
http://turbotbird.com/techinfo/Idle-TPSa...e2005.html
Littlehoe
Sep 2013
10-11-2013, 01:15 AM
(This post was last modified: 10-11-2013, 01:16 AM by Littlehoe.)
yes I followed that to a T. I have now hooked up a vacuum gauge to the tree and it is only showing about 10 when the car is idling with the miss. Add some throttle and the vacuum goes up but still not to the spot it should be.
Could it be that I don't have the cam timing set properly, that is the only thing I can think of now... maybe one tooth to late? I know I was having issues lining up the crank mark with the tc and then getting the cam marking to the middle of the three tabs. It appeared a little ahead or behind, never exactly where I thought it should be.
So in your guys opinions should I attempt to advance the cam one tooth and try it again that way?
Also I am only getting about 9 psi boost. is that normal for a stock auto?
