sctur601
Apache Junction, AZ,usa
Post on turbo ford by J.D. Laramee.
THERES IS A 2.3 ROUND PORT RANGER HEAD. WHEN I GAVE THE HIGH FLOW NUMBERS ON THE TRICK FLOW POST. THIS IS WHAT I WAS USING. PORTED THEY WILL OUTFLOW THE OVAL AND D-PORTS EASILY. BUT ARE ALOT OF WORK.,J.D.
The problems with the combustion chamber are easily dealt with, It doesnt take much grinding to make that chamber the same ccs as the turbo head, plus you will have less shrouding of the valves when you are done cutting. If you plan on porting the head it looks like it would work very well, the only other problem is the end ports on your intake are wa too big to match up with this head, but there are ways around that. [Image: biggrin.gif]
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
273rwhp and 342ftlb at 24 psi with a slipping clutch!
And it still feels slow!
Thanks
Shawn
Please click the link if you want to sign my aftermarket head list
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
I also do port work, if you need something ported email me at [email protected]
Jonesy
Jan 2002
Hartford, AL, USA
Do tell!!!!!!!!!!!!!!!!!
I should have the head here by next week, then off to the machine/head shop. What exacytly should I tell them?
Michael "Jonesy" Jones
87 Medium Red Clearcoat Metallic 5 speed
2 Tone Leather Interior, All options including factory sunroof/moonroof
168,500 miles - So Far
Mainly stock, K&N Filter, custom ram air
New paint job COMING SOON(repainting factory med. red with ghost flames.)
67King
Jan 2002
Saline, MI
For whatever it may or may not be worth, a head has two different part numbers - the casting is one, and the finished (i.e. machined) head is another. RF.....means "rough finish." In other words, that is the part number for the casting. You may find the finished part number engraved into the head somewhere. It will have four charaters (alpha-numeric), then the numbers "6049," then two letters. The casting will be RF____ 6C064 __."
89 XR4Ti, a work in progress
67 GTO
2000 Harley-Davidson F-150
67 GTO
methos
May 2001
Cynthiana, KY
Since I have talked with JD alot about his porting of the open cahmber ranger head I can tell you this about it. They were only made from 1983-1985. They were put on 2.0's and 2.3's. if it is a 2.0 head, it's junk and can't be ported worth a damn. The 2.3 head that he ports is his own porting that so far has only gotten close by his old competator that now works for him. Combining both their skill and ideas, they have a 2.3 head that out flows it all. He charges (last I knew) $2100 for a complete ranger round port setup and port job. He has LOTS of orders for these things and they are getting harder and harder to come by. Also, they were never made with an efi intake so making it fit right might make it harder to use in our motors. But because he hogs it out so much... might be less of a problem making it work with our intakes.
And on another note, he has a 300hp n/a 2.3 in a pinto running 10's or so
oh yeah, and another interesting thing.. I get turbo heads from work that are what we call cores cheap... $75 complete and they are supposed to be guaranteed crack free. Email me if you need one.
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods:
Esslinger Prepped head, AiResearch T-3, 3.73 gears, Schneider custom grind cam, chromed rims, dynomax on the duals, and last but not least... new interior
AIM - Shizniblit
[This message has been edited by methos (edited 04-04-2002).]
Jason Schaffer
Mods: 3.73 Gears
Finally getting it back together.
Jonesy
Jan 2002
Hartford, AL, USA
Methos, email me, your email addy link above bounces back
[email protected]
GT350R
Cleveland
Mabey he would be interested in buying a NOS one. Jonesy might be able to walk away with a few bucks to help pay for a ported head!
GT350R
(sold ) 87 5speed, Motorsport head, A237@+2, T3@20psi, gutted or ported everything & all the typical junk.
84 Gt350 2.3T T-top
84 Turbo GT 418rwhp
My Garage
