KentCT88TC
Oct 2006
Beacon Falls, Connecticut
Took my recently repaired TC on a trip down to Skyline Drive VA and back to CT last week, putting on about 800 miles. On the road, I got over 30 miles to the gallon, running 70 - 75 mph, using the AC most of the time. Was glad to see this kind of results. I use 93 octane with a can of octane improver. Got several compliments from people on the car. After I adjusted the lumbar support, had no back problems sitting in there for eight hour driving stints. Also, with the new aluminum radiator installed after the accident, and a new air dam (Mustang GT style), that engine ran cooler- at least 20 degrees less than before.
-KentCT
-'88 Turbo Coupe, K&N, Gillis valve @18 lbs., 2.5 " exhaust.
-2000 Mustang GT 373 gears, Diablo computer chip, cold air intake, Typhoon intake manifold.
-2001 Jeep SE 2.5, AEM cold air intake, Gates headers & exhaust, throttle body spacer, Jet Stage 2 chip
Rob..
Nov 2009
Naples, Fl
You should do the mass air conversion, you'll get even better gas mileage. I just drove from Naples to Orlando for training. I filled up just before getting on the interstate and got...(drum roll please)
...41.9mpg.
I got there and back on one tank of fuel. I love these cars.
BTW, I NEVER turn off my AC. As a matter of fact we tuned the EEC with it on MAX AC since I always have it on.
I want to live in a world where monkeys don't dig up the dead and parade about in their shoes.
88 7F, SS big valve head, port matched in/ex, gutted and powdercoated intake, A-237, stealth T3/T4 Garrett hybrid, Abaco 85mm mass-air meter conversion, tripminder, Walbro 255 high pressure, SVOJohn tuned.
...41.9mpg.
Do you give the credit for that mileage to the mass air?
Both of your numbers are very impressive for a 22 yr old car, but even better it is as good if not better than most new cars.
Rob..
Nov 2009
Naples, Fl
I would say it is the largest contributor. My car has been lowered too, so aerodynamically that helps as well. I didn't get this kind of mileage before my conversion. It was good but not like this. SVOJohn tuned it but says none of the other cars he's tuned gets mileage like I do. I would also say that it's not just the mass air conversion, but the type of meter used in it. I have an Abaco 85mm DBX digital air meter. The signal is super-clean, providing extremely accurate air measurement which is key in getting good gas mileage. It's expensive, but with the price of premium fuel, it has paid for itself several times over. I would not recommend any other meter, period. They are subject to vibration, reversion and turbulence. All of which gives you a dirty signal. Your car may run OK but you won't receive any mileage benefits, your car will only be marginally better than with the VAM.
