Quote:Need some help really bad guys
Since you asked for help from the really bad guys, and my wife has occasionally insinuated that my mechanical skills are really bad, here's my two cents worth of knowledge:
I did it on an old Subaru, a few different times, a long time ago, not a TC. At the time, I had an unlimited supply of tools at my disposal, including a hydraulic engine hoist and a couple of floor jacks. It was real easy, since I had the option at any given point of lowering the engine or raising the car. I had pulled the radiator but not the A/C condensor, and in THAT car, it gave me enough room to lower the engine, slide it over the shaft, and get all the bolts threaded (but not tightened). Occasionally, I had to press down on one end of the engine while raising or lowering the engine to get it to line up the way I wanted. After everything was aligned and threaded, I tightened the bolts.
I don't know if this is any help to you, or if it even transfers to the TC, since the Subaru engine is a horizontally opposed four-banger.
Mike Walsted - Nato member
1986 5-speed TurboCoupe .
[This message has been edited by Walsted (edited 12-18-2001).]
