FatDave
Jan 2007
Robertsville, Missouri
hey all,
while warming up my TC (and letting the battery charge) i noticed my odometer slowly climbing while just sitting there, then the speedo and tach needles started to shake (not wildly). is this an IVR problem? or should i get an old priest and a young priest and a gallon of holy water?
1985 TC 5 speed, 152xxx miles.
1988 Honda Accord LX-i coupe.
1989 Chevy SS454 Clone pickup
1992 Ford Explorer 4x4 5.0 swap
Mike C
Sep 2005
Bellmore, NY
Whenever my battery voltage was low the speedo on my 86 would "sputter" from 0-10. When I took off or raised the Idle it would go back to 0. This has been my first indicator of battery or alternator problems, or even a loose fan belt.
HTH
Mike C
86 5 speed TC black with MS spats and spoiler since 88, 3.73 8.8 since 89. Fresh rebuild at 240K with new Racer Walsh roller cam, 88 hood. All 3" exhaust w/3" performance cat. 13" Cobra brakes,SFC, Max/Motorsport C/C plates,adjustable lower control arms w/ double adjustable uppers. Konis & Eibachs.
FatDave
Jan 2007
not really a sputter, just shaking. new battery fully charged, but seeing as it sat awhile i started it and let it warm up when i noticed it, and its the trip odometer that is climbing about 1/10th a mile every 10 sencond, strangest damned thing i'ev ever seen
Seen this a few times before. Electrical noise causes this. Possible causes of electrical noise: Bad alt (usually one phase shorted / open), bad / corroded major power or ground connections (batt cables, engine - frame ground, batt ground, etc). The problem is NOT the IVR, as the IVR only controls voltage to the temp, oil, and fuel gauges, and not the speedo and tach.
FYI, it isnt uncommon to see the speedo make a little "jump" each time the turn signals flash, even when everything is working correctly. Even this can be eliminated by putting a 4700 or so microfarad capacitor between the cluster 12V supply and ground to act as a noise filter.
Matt S
Mountlake Terrace, WA
My speedo jumps when I step on the brakes. That's better than the system sentry
Sold it *
fiveliter8
Nov 2003
o'fallon MO
Remove your instrument cluster and clean off the the connections on both the harness plug and cluster. A good pencil eraser works wonders for doing this. I had two cars that did this and it was because of poor connections. It also helps to bend out the terminals ever so slightly on the harness connector so they mate with the cluster better. Hope this helps,
Alex
www.stangnut.com
1988Tcoupe-ye will be missed
'09 Flex SEL
1984 20th Anniversary GT350 Mustang 'Vert
1984 Mustang GT T-roof
1965 Shelby Cobra Replica
