TurboBays
Nov 2002
Sophia,WV USA
I am getting ready to replace my IHI turbo with a garret T-3. I have an 87tc and will it fit right or do I need to buy something extra. I been reading these boards and people talk about turning the boost up. How do I do it? Do I need a gillis?
natmac3
Mar 2002
Aberdeen, MD
Not to be an ass, but if you have to ask after being around for 100-and-some-odd posts...
ON EDIT: Note to readers- The views and opinions expressed by "natmac3" do not necessarily represent those held by NATO or any of its other members. Thank you.
[This message has been edited by natmac3 (edited 06-11-2003).]
1987tc
philS
Bellingham, MA
make sure you get a T-3 from an SVO, or else get one rebuilt so it has the SVO-style compressor housing
how do you plan to feed the intercooler?
Gillis valve is your friend!
86 TC 3" Exhaust w/ Cat, 17 psi, 1.5" lower, Vovlo intercooler, Saab 900 cooling system
73 Austin Mini 1275
Click here to beat a ricer.
deadlyfoe
Aug 2004
orangeville,Ontario,Canada
I have a garret T3 on an 84 t-bird that I will be adding an 88 intercooler to and I was wondering if it is possible to turn up the boost with a stock setup?
Deadlyfoe, try at your own risk.
Thats actually not how it works. On the compressor, there is a "T" with one
side going to the wastegate and the other side feeding the BCS. The other side of the BCS goes to the turbo inlet. When the BCS is activated, is bleeds signal away from the wastegate and back into the inlet and raises
the boost. If you bypass the BCS with a butt splice, you have a full time bleed.
The 12 gauge connector bleeds enough to raise the boost to 15 psi.
Note, this may give more than 15 psi boost. using a blue butt spice reportedly will give around 17 psi. I never tried this so you are on your own. Or more prudently, buy a Gillis valve
Dedpedal
Aug 2004
Ft Wright Ky USA
Ive been playing with the IHI on my 87 motor and got 15 psi by bypassing the bcs completly. I went to Petsmart and bought an air control valve for a fish tank. It keeps boost in the 10-12 range with the BCS missing. I wasnt to thrilled about not having any way to limit boost. I want to go with a .60/.63 T3 in the near future as I have one thats water cooled as well as one thats not. I planned on using them on a twin turbo kit for my GT.
87 Turbo Coupe
Ultimate weight reduction. A 93 Mustang coupe body.
B_Lieder
Jan 2003
Salem, Ohio USA
I have done what pete is describing. I have never gotten more than 18 psi on the gauge (but how accurate is that gauge), but my overboost buzzer has gone off a few times.
Bill L
illwill
Jul 2004
Lynn, MA
wrong screen
Late 84(quad koni-shocks) SVO sunroof/leather 9W (1 out of maybe 150 made). 88 5 Speed Turbocoupe; ported e6, roller cam, dual 2.5" dynomax, gillis valve, T3, sequential turn signals.
[This message has been edited by illwill (edited 08-06-2004).]
84(quad koni's) SVO sunroof/leather 9W (rarer than most). 88 5-Spd TC; ported e6, ranger roller, 2.5"dp > dual 2.5" dynomax ultraflows no cats, boost 20psi, T3, sequential turn signals.
deadlyfoe
Aug 2004
I was looking and my car doesnt have a BCS
There is no T connector there is just a single vacumm line that goes to the wastegate.
