bobs 88 tb coupe
Jun 2004
lorain ohio
i have a 91 mustang 5.0 and was wondering will that fuel pump and injectors go into my turbo coupe and how would perform????
And how many # injectors do you think they are, and do you think that is a 190, or a 255 pump??
thanks
[email protected]
The Mustang injectors are high impedance and the TC are low. You can't use them. Although I don't know for sure, I susp[ect the Mustang ones may flow less. I also don't know what the rated capacity of the Mustang pump is but it may not be any larger than your current TC pump (88 lph). If you are going to be making mods, just get a good sized Walbro (255 HP) pump from JDs
rc_av8r
Jul 2003
Decatur, Al
The fuel pump is the same but the injectors, even if they would work are much smaller, they are only 17 pound. A good mustang upgrade is 24 lb. injectors which is still smaller than the factory TC ones.
87 TC: A237 Motorsports cam, boost valve,MSD 6BTM Rod's header, 3" downpipe, dynomax ultraflow mufflers, 2 1/2" GT tailpipes.
88 TC: 5.0 Conversion,Edlebrock heads and upper-lower intake, rockers, exhaust, dynomax race magnum muff.,24lbs. injectors, waiting on supercharger.
87 TC: A237 Motorsports cam, boost valve,MSD 6BTM Rod's header, 3" downpipe, dynomax ultraflow mufflers, 2 1/2" GT tailpipes, 255lph fuel pump, adj. fuel press. regulator.
Stock 5.0 HO injectors are 19 lb high impedance. Stock TC injectors are either 30 or 35 lb low impedance, depending on year of the car. Wont work.
rarebird83
Jan 2004
thonotosassa, fl
the fuel pump is the same
