Front Suspension Rebuild; Same as SN-95??
DanMarshall Offline
Just wondering if the SN95 mustang and Turbo Coupe front suspension are the same. I need to rebuild the front suspension (Control Arm, Control Arm Bushings, Ball Joints and Struts) and was wondering if i could purchase SN-95 Control Arms and Ball Joints and if they would be a direct fit onto the Turbo Coupe Front end. The reason i ask is because i herd people were able to put SN95 Springs into their cars no problem and it spiked my interest. If anyone could help, that would be great.
1988 TurboCoupe 5 Speed 130,000 miles
1998 Ford Escort SE (Daily Driver)
deadbird Offline
interested in this..../
1987 5 sp.
- 4.6 2v swap.
Not B Anymore Offline
You can use the SN-95 control arms - they are dimensionally the same, but you should use the T-Bird/Cougar ball joints. The stud on the SN-95 ball joint is shorter and have a different thread pitch. There are those who have used them, but I'd play it safe and use the T-Bird ball joints.
BJL Offline
Moderator
yes control bolt directly into the k-member.
the ball joint is the difference as "B" said.
i am using sn95 control in my TC but um also running SN95 spindles and hubs.
if you swap in TC ball joints dont go cheap, i ran the lower grade in my all stock 87 tc. they pressed in too easily in my opinion. i had this same issue on customer's car when using the lower grade ball joints. I have moog in the 88 with the SN95 set up.
Brian Larkin
88TC 330,000 miles
Slightly Modified
Redbone Offline
Are the V-6 and V-8 control arms the same or do you have to use the V-8 ones? Thanks.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
BJL Offline
Moderator
Redbone Wrote:Are the V-6 and V-8 control arms the same or do you have to use the V-8 ones? Thanks.
they are the same.
Brian Larkin
88TC 330,000 miles
Slightly Modified
