RDOG
Jun 2001
Ontario. California U.S.A.
I originally put a set of 94 Stang springs in the rear and 4 cyl 1987 mustang springs up front, but they are starting to sag and my car now rides like a bouncey ricer. I talked with Eibach and they said they would make a run if I got 25 sets minumum. The guy could not find the part# though in order to check the specs for me. Anyone know the part# so I dont have to wait for this rookie to find it.
bak2423
Nov 2002
Philadelphia, PA USA
Hey RDog. Sorry, I do not know the part number.
But, if you do get sets, I'd be interested, depending on price of course. also, is this all four, or just fronts?
DrPhang
Petersburg, Virginia,
If Eibach would do a limited run on springs for out car I would NOT pass it up
87tc
Dec 2002
reno nv US
gtbird
Dec 2001
Hope, RI 02831
I'd be interested if the price is reasonable.
Rick
2ManyRecklesses
May 2002
chesapeake va usa
do a search for the old topic "Would you buy a set of Eibach's if available?"
"It takes two to lie, Marge. One to lie, and one to listen" - Homer Simpson.. my hero
87tbirdtc
Apr 2002
Bakersfield, California
i would buy a set if it is for all four springs and if the price is right
87 Medium Red, 76,000 miles, K&N on VAM, Gillis boost valve set to 17 psi for now, Reverse indiglo gauges
You shouldnt need the part # its the Pro Kit for an 87-88 Turbo coupe 4cly or tbird V6. Its the only kit they offered for our cars, ask him to talk to other people at eibach that might know, about a month and a half ago i was asking questions about our kit and i finally talked to someone that gave me the spring rates of the back and front springs the first and second rate. At the time i was asking to compare a similar spring rating they still offered, No luck. When i talked to them they said the last time they sold a kit was in 1999.
-88 TC Black
-97 Pathfinder
66fairlane
Aug 2002
Sacramento, Ca
the part # is 3516.140
1987 Ford Thunderbird Turbo Coupe
2002 ford Ranger Egde
2006 WRX
tornado427
Nov 2002
Milan NM USA
COUNT ME IN!!!!!
88 TC all options except leather, soon to be 5 speed, working on performance mods. 78 cobra II with 302 HO & shelby dual quad intake,427 chevy 4x4 (so its not a ford, it still kicks ass!)1961 kenworth classic, 500 HP & BIG turbo!!!
88 TC all options except leather, T5 swap, K&N in fender, Gillis valve, 78 cobra II 302 HO 4 speed, 95 mustang GT convertible 347 stroker, Trick flow track heat top end, powerdyne blower 10 lbs, devils own dual nozzel methanol injection, Astro A-5 trans, Detroit locker 31 spline moser axels, 3:55 gears (stock block time bomb)
