Ricky03
May 2004
Bumpass, Va. U.S.A.
Ha e a code 83 showing a d the bad miss is back after a out 10 minutes of driving. Miss starts at 2800rpm
Code 83: Check EDF signal to Integrated Controller for open circuit.
http://www.tbirdheritage.com/turbocoupe/...-Chart.php
I'm guessing the engine miss may be a separate issue.
Ricky03
May 2004
Bumpass, Va. U.S.A.
What is the EDF and is the inergrated controller the IRCM?
EDF = Electro Drive Fan - the cooling fan(s) 2 on 87-88s
Yes, the integrated controller is the IRCM. Among others it has a relay for each fan. Also relays for the fuel pump, A/C clutch and power to the EEC
HDEF is another acronym for the fans
On the TC, the pass side fan in the EDF, and the driver side fan is the HEDF.
