Dan E
Greensboro, NC
http://cgi.ebay.com/ebaymotors/ws/eBayIS...1846562411
I e-mailed the seller to verify if this will work on our TC's...
Dan Eaves
Grant
Jul 2002
Thomasville, GA
http://www.coolcats.net/tech/beginner/ts...index.html
Here's an install of sequential lights, if it helps any. The kit seen here, however, costs like $150, if that company is still around. [Image: frown.gif] If that other setup will work, that'd be cool. Later
83 TC : full 3" exhaust, 17" 93 cobra wheels, many mods awaiting install once the engine's back in
RiglerTKE
Jul 2002
Richmond, VA
I'll chip in if you want to get one to distribute to everyone. I didn't see where he listed it as copywrited!
Todd Rigler
87 TC Stock except for brake swap.
RiglerTKE
Jul 2002
Richmond, VA
I e-mailed the guy and this was his reply:
As long as your taillights have 3 bulbs each side, no separate amber turn signal, and the brake and turn signal use the same bulbs, it will work.
Todd Rigler
turbokev
Mar 2002
Exeter, NH USA
Good luck building your own kit..
I paid the $150 for the kit mentioned on cool cats and what I got was a very high quality solid state box all pre wired and ready to install. The sequential lights on my '88 work perfectly.
Kev Schofield
1989 Corvette
85, 2x86, 87 & 88
(former TC's)
87tbirdtc
Apr 2002
Bakersfield, California
i have the sequential tail light in my tbird and on the driver side the light nearest to the license plate is dull and the other two are brigther and when i turn on my headlight the dull one turns brigther than the others i dont know what is wrong with it. it is not the bulb i already changed that can anyone tell me what to do to fix that problem thanks
JLockhart
Jan 2002
Dallas, TX
TurboKev,
Did you have to change the bulb/socket on the inside lights to dual filament? I figured I'd want to do this so that at night all three lights would have 2 levels of brightness.
87 TC, T5, t3/t4, alky spray, 3" exhaust. 13.65 @ 102.75 on radials
BROTHER-Rebel-OUTLAW
Dec 2001
Ontario, Canada
The two inside tail lights are usually 194 bulbs. If you changed the bulbs to 904 I think the lights will be brighter.
Keep the shiny side up and I'll see you in the fastlane!
->JP
"I didn't think it was possible,
but this thing both sucks and blows at the same time" -Bart Simpson
BROTHERRebelOUTLAW
Hi, to me that ebay thing sounds a little questionable, thats all info that can be found on the net for free. Just type "fiero sequential turn signals" into google and click on FILEZ [Image: wink.gif]
I created my own STS system for my T-bird that uses relays www.geocities.com/stsofirepinto
The site explains how it works and what parts to get.
87tbirdtc - it sounds like u might have the dim and bright filiament wires switched around on that one bulb. Or check to see that there is a good ground.
87tbirdtc
Apr 2002
today i checked out the wiring eveyting is okay could it be the capacitor
