kwiksilver3441
Feb 2003
La crosse/WI/USA
anyone ever had a blinking firm ride light? if i turn the switch for the auto ride to firm the firm ride light will flash 3 times and then go off, it does this over and over. but if i am at a stop and turn the switch on the ride light goes on and no probs? any suggestions on where to start loking for the culprit
Error Code 3: pass side front activator / position sensor problem: The PRC computer is telling you that either the RF PRC activator is not in the commanded position, or the position sensor is not telling the PRC computer the activator is in the commanded position. If it sometimes works, and sometimes gives the code 3, the problem is intermittant.
Easy test: switch the RF and LF activators. Should result in a code for the LF (code follows activator), which I THINK is code 4, but might be code 1, it the activator is the problem.
Activators can be disassembled and repaired fairly easily.
Scroll down just below this article to see an article on fixing the actuators;
http://www.turbotbird.com/FAQpage/FAQpag...20Problems
