88onponys
Oct 2008
San Leandro, Ca
i installed my gillis today i had the boost set to 15 next thing i know boost gauge sarts reading like 1 or 2 pounds of boost
i here the turbo spooling but i dont see the gauge moving i think its a lost of boost but i dont know were
thumper
Jun 2001
Dexter, MO
Do you feel the turbo kicking in? If the car isn't a dog, then the turbo is definitely working, at least partially.
If you have the stock boost gauge, its your likely culprit. They are notoriously unreliable with age.
The aftermarket boost/vacuum gauge I bought was one of the best investments I've made in a while. Not only does it give you a window into your motors health, it lets you know when you are getting the best gas mileage (right at around 10 inHg)...
A.K.A. Corey Bennett
goodstuff84
May 2008
Attleboro Ma
Check all your vacum lines, I had a vac line on the vacum tree blow off under boost and it made my boost gauge do funny tnings, wouldn't read more than 2-3 psi of boost or anthing below 8 inches of mercury on the vacum side, if the turbo wasn't boosting you would know it, there would be a huge decrease in performance, most likely accompanied by some sort of smoke or howling from the turbo, probably just a loose vacum line somewhere
Justin
88 TC, E-bay 50 trim t3/t4, ported E6, Volvo FMIC, Forge BPV, walbro 255 HP pump, Kirban AFPR, RAM clutch, full 3" stinger single exhaust w/dynomax muffler & dumped at axle, K&N cone on the VAM, *13 base timing, boost @ 20psi. http://s661.photobucket.com/albums/uu337/Goodstuff84/
88onponys
Oct 2008
San Leandro, Ca
thanks for the help i drove the car this morning its making boost the gauge still reads 1psi
does anybody know on the vacummn tree what g stands for it was cap off thats the vacumn source i used for the gillis
It does not stand for "Gillis"
It doesn't matter.
xcrunnerbd
Oct 2006
Woodland, MI, USA
I thought the "G" on the vac. tree stood for "Gauge." That is the port my factory gauge was hooked to. But, as Pete said it doesn't really matter.
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
88onponys
Oct 2008
San Leandro, Ca
when in got the car the port was plugged so i dont know where the gauge is getting a vacummn/ boost source
The gauge should have a line hooked to the back of it, in the pod. The line runs through the fire wall to that vacuum tree
