SVO Valve Cover on an '88 TC engine: Does it work? - Printable Version +- North American Turbocoupe Organization (https://turbotbird.com) +-- Forum: General, Technical & Performance (https://turbotbird.com/forum-general-technical-performance) +--- Forum: General Discussion (https://turbotbird.com/forum-general-discussion) +--- Thread: SVO Valve Cover on an '88 TC engine: Does it work? (/thread-svo-valve-cover-on-an-88-tc-engine-does-it-work) Pages:
1
2
SVO Valve Cover on an '88 TC engine: Does it work? - DanMarshall - 05-09-2014 I haven't posted here in a while because original engine in my '88 TC took a crap on me and had little to no compression on the inner two cylinders. Recently I purchased an '87 Turbo Coupe with under 100K miles with a rebuilt cylinder head for $500 For it's engine to swap into my '88 TC. With finishing up the most recent detailing on the engine to make it look nice I noticed something: the back oil breather hole on the '88's valve cover is huge compared to the SVO's valve cover that I planed to install. Is there any way to run this valve cover without having to drill it out to fit the 88's oil breather line? My mechanic who has worked on many fords said if I bypass it and run just a filter in the hole that I will get a lot of oil seepage. Would love to hear if there's any way for me to put this valve cover on. I spent a lot of time restoring it and I think it would dress the engine up a little bit more with the SVO VC. RE: SVO Valve Cover on an '88 TC engine: Does it work? - Not B Anymore - 05-09-2014 Sounds like that valve cover uses the earlier-style breather. The 83-86 TC's have a breather that just goes in to that hole without a rubber grommet (metal-to-metal), and the hole in the VC is smaller, as you describe. If I were you I'd first try sticking your breather in the hole, but not with any grommet. If that doesn't work, find an earlier one and it should work. You do not want to just run a filter in the hole. You can do a catch-can setup without issue. RE: SVO Valve Cover on an '88 TC engine: Does it work? - Jeff K - 05-09-2014 Have you checked the clearance between the SVO VC and the throttle body and throttle linkage? The 87-88 TC VC's have that depression under the TB for clearance reasons. RE: SVO Valve Cover on an '88 TC engine: Does it work? - DanMarshall - 05-09-2014 I never put that into perspective. I know side by side the SVO VC is alot shorter in height so I figured it would fit under the Throttle Body no problem. Is there anyone on here running an SVO VC on an 87-88? RE: SVO Valve Cover on an '88 TC engine: Does it work? - natmac3 - 05-13-2014 http://4.bp.blogspot.com/_iSUU432vhTA/THlqNw-JMhI/AAAAAAAAAA8/8pknVbAAYAw/s1600/StockEngine.jpg I used a homemade spacer between the upper and lower intakes to fit an older style cover on my 87tc. Now I use a rotated plenum, but the spacer and some longer bolts from the hardware store worked great. RE: SVO Valve Cover on an '88 TC engine: Does it work? - boosted chicken - 05-17-2014 Sounds like you just needed a new headgasket on the 88 motor and with only 130k miles, the rest of the motor should be in great shape. Would have been a lot easier than an engine swap. Just sayin' RE: SVO Valve Cover on an '88 TC engine: Does it work? - RDOG - 05-18-2014 You will have to open the hole if you want to make the job easy. Then you can re-use all your stock breather stuff. I opened mine to 1" hole slapped the 88 grommet on it and went about my business. You will also need to make a 1/4 inch spacer so that the short upper will clear the nonhumped VC. I just took a old upper I didnt need and cut the lower 1/4 section off. Makes for a perfect spacer. lastly you can use a 80's ford tempo breather or mercury tracer breather for a nicer low profile breather.(You will have to open the hole to 1") It makes dealing with IAC and tps much easier. RE: SVO Valve Cover on an '88 TC engine: Does it work? - Ramos617 - 05-18-2014 RDOG Wrote:You will have to open the hole if you want to make the job easy. Then you can re-use all your stock breather stuff. I opened mine to 1" hole slapped the 88 grommet on it and went about my business. Thanks for the tips, but I gotta ask. Why can't you just use the pre-87 breather? Is there a reason to go with the 87/88 breather? RE: SVO Valve Cover on an '88 TC engine: Does it work? - RDOG - 05-19-2014 Ramos617 Wrote:RDOG Wrote:You will have to open the hole if you want to make the job easy. Then you can re-use all your stock breather stuff. I opened mine to 1" hole slapped the 88 grommet on it and went about my business. They are a b*tch to make seal. I tried RTV and all ,inds of other stuff and it just never completely seals. It took all of 5 minutes for my cousin to open the hole up for me, and thats all do to him setting up his machine. A local shop wont charge you over $20 to do it. RE: SVO Valve Cover on an '88 TC engine: Does it work? - DanMarshall - 05-20-2014 so the 88's Throttle Body isn't a problem with clearance on the SVO's VC? |
