yet another problem..no boost
vfast Offline
this car is turn out to be a POS...I finally get a lil time to look at my sons car to fix the brake problem and now there is 0 boost..I rev it up to 4500 and nothing as the rpm's fall the guage shows a boost flash for a sec that's it?...any thoughts....I'm a supercharger guy..
Gulfdiver Offline
Check the IC hoses.. and make sure they aren't torn..
!!!!! MINE ALL MINE !!!!!
1988 TBird Turbo Coupe Mach 1 Special Edition
K&N airfilter; Spec Stage 3.. More mods to come!
vfast Offline
will do
Are you talking about free reving it in neutral? If so, it shouldnt develop much, if any, boost. When free reving, there isnt much load on the motor, exhaust flow is too low to spool up the turbo. Motor must have a load on it to produce boost.
vfast Offline
yes in park...THX again jeff!
Ryan H Offline
What did the boost rise to in neutral? I get about 14.
svo_thunderchicken Offline
Most of these cars wont boost much at all with no load on them... the small rise you get is what mine did when the waist gate accuator came unhooked. Check the accuator...
84 TC Silver 5 speed - PE EEC, Big Vam, RR cam, 35lb injectors, E6 swap, T3 60 Trim, 87-88 intercooler and hood, BOV, K&N Cone Filter *under constrution*
http://www.cardomain.com/ride/2298891/1
87 TC Black 5 Speed - Stock IHI, BCS Bypassed
http://www.cardomain.com/ride/2390431
Ryan H Offline
Ah, I'm not running a wastegate actuator. Or a wastegate, for that matter.
im talking about vfast :-)
