Yellowed Headlight Lenses
turbocoupes Offline
I've noticed a lot of people purchasing new headlamps for these and other vehicles when it isn't neccessary...why?...my solution for years has been a high quality polishing compound...if the problem is only external...polish them...polishing last according to the condition the lamps are exposed to...I polish mine about 2 times a year...alot cheaper than replacing!
Birdoprey always in flight
83 86 87 87 87 87 TC
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
89gted Offline
What do you polish them with?
[Image: th_TC016-PaintShiney.jpg]
Another proud dues paying member.
88TC, 210K, Black/Raven, Auto (may change), 140 speedo (by Jeff K), trip computer, 3G, cold air K&N, improved IVR, new AC system, new windshield & 360 tint, new sensatracs all around, interior cleaned up like new, now for the outside....
turbocoupes Offline
sorry left some info out...I use Turtle Wax Polishing Compound with a buffer ...like the Auto Detailers use...
Glenn 88TC Offline
I heard that toothpaste works great also.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, TE60 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
I they are realy bad, first wet sand with 600 grit, then 1000 grit, then 1500 grit, then rubbing compound, then polishing / buffing compound.
