yellow anti lock brake light on
terr5178 Offline
The yellow antilock light goes on when I start the car then turns off after a couple of seconds. Once I start to roll the light comes back on.. What does this mean and how do I diagnose the problem??? Also the antilock breaks definitely do not antilock when the yellow light is on..
flyinhigh Offline
if you follow the troubleshooting guide you can find out what is wrong
http://www.turbotbird.com/techinfo/TEVES...%20TCs.htm
Black 87, custom door panels, HE351 Holset, Kirban, tube rotated upper intake, ported lower, mild ported head, Stinger header, 3" exhaust, Turbodad MS system, Big FMIC, LS truck coil conversion, 135 Amp alt, expolorer radiator.
1988turbotbird Offline
the abs dont work when the abs light is on is because when the light is on, there is a problem with the abs. If the abs has a issue, it defaults to not working have you got abs codes? the diagnosis connector is by the spare tire
