v8mazda351
Nov 2005
new castle
wow, i just put a t3 on my car and holy cow, what a difference. ihi's suck!
=) sorry for the useless random stuff
trashline
Feb 2005
Levittown, PA
so what is your technical questions or response? I dont have a problem with my IHI
Melon
Nov 2005
Blair, Nebraska
Is it work the effort to swap the IHI for a T3 on an 87/88 TC? If/When I get an 87/88, I'm considering that swap if I come up with a T3.
-Melon
trashline
Feb 2005
Levittown, PA
-Melon
do some searching theres plenty here and at turboford.org. a larger turbo is alway better thats why people upgrade to them. if you dont raise the boost past 15-18 psi then id say the IHI is fine the t3 is good to about 20-22. but boost from a t3 at 18 psi is different then the boost at 18 psi on the IHI.
Ryan H
Oct 2004
Panama City, FL
The stock IHI runs out of steam at around 4,500 RPM. The stock cam drops off around 5,200 RPM. On a stock '87/'88 TC motor, your powershifting point should be somewhere around 5,000 RPM.
When you make the IHI boost past 4,500 RPM, you're not making much more power, and you can feel the torque die off. I almost never go past 5,500 RPM with my car, not because I'm scared but because with the stock cam and turbo, its pretty much pointless...
Melon, nice looking MN12
turbotronic
Oct 2004
Stillwater, OK
I like my IHI. It's good for the quick spool up and in-town driving, which I do alot, I don't go out of the city much at all.
~Mark
88 TC (Black), 5 speed
FMS 140MPH Speedo
Oval Port Head
1.59/1.89 SS Valves
APC Cone (I know...Ricer part)
Gillis valve
TurboXS BOV-RFL
Alum. Water Pump
Walbro 190
3G
88 TC (Red) [Parts Car]
trashline
Feb 2005
Levittown, PA
i dont have that problem my IHI pulls strong to about 5000. ive never went higher then that in the rpm range on my car.
Ryan H
Oct 2004
Panama City, FL
You also have 3.73 gears out back. I mainly felt this with the 3.55s in my last car, but I can still feel it in my current one.
V6TBird87
Apr 2002
Severn, Md, USA
You guys talk about how the IHI is fine, im guessing you havnt driven a car with an IHI, then a larger turbo huh?
My IHI took a dump, swapped a larger turbo on, has a .63 housing, and i actually picked up bottom end torque off of boost compaired to the IHI, and power under boost is incredible compaired to the IHI
the IHI is barely sufficient for a 2.3L
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
