Wobbly Steering Wheel Fix
vegas_ss Offline
Needing to replace the ignition switch which basically fell apart, I noticed the mounting area was a little loose.  The steering wheel itself had some play and I had found the repair was pretty simple as there are two bolts that need to be tightened up.  It was suggested to use locktite and seemed like a pretty simple fix.  Problem was I couldn't locate these two bolts!  Finally found them after removing the turn signal stalk and thought I would post a picture so others may find them a little easier.  Steering wheel and ignition switch mounting area is nice and tight now.  Hard to see in the pic so I circled them in yellow.  They are right behind the turn signal stalk which is easy to remove (two screws).
Mikey97D likes this post
Kuch Offline
nice pic for reference. Thanks Vegas
