WiredFalcon
Sep 2009
Michigan
Im looking for a wiring diagram for the instrument cluster on an 87 tc 5 speed the massive plug has so many wires in really only need to no which one from this plug powers the dash lights to see if its is burned up fuses are good dimmer is good i would like a full diagram if available. also th e clock worked until i put in a radio/ cd player any tips on that would be great also.
There's a bird in all of us!!!!
junkedturbo
Apr 2008
Batavia IL
Are you good at reading wiring diagrams :confused:
Get ahold of a Chiltons book and it'll have all the answers to your problems, the book will even label what wire is what coming from the pigtail.
After looking at the wiring diagrams for awhile it'll make you want to rip out all the wiring in your TC and make your own that easy to understand and fix
Joe F
Jul 2002
Hawkins, Texas - USA
HERE you go. From the Custom Instrument Cluster article on my website .
HTH.
WiredFalcon
Sep 2009
Michigan
Thanks helps more then the last guy book don't tell me nothing I would have been better using a mustang fox body body book then shelling out for the turbocoupe book everything is the same other then brakes
