wing installation
djmikemck Offline
I have an 86' turbo. I have had a wing from an 83 firebird looking at me all winter. I was just about to drill into the trunk when I noticed that to line up the wing on the trunk lid, I would not have a long enough screw to get through the trunk interior. Does anyone have some advice or pictuers from inside the trunk to help me out. Thanks in advance!!
Mike
The obvious answer: Get some longer screws!
What exactly is the problem? Would the wing support legs be right above some of the trunk bracing sections? If that is the case, just use a 1" or so hole saw to cut an access hole thru the bracing where the screws that hold the wing on need to go.
