Window Regulator Clips
EricEaves Offline
Hey guys! I'm pretty sure I already asked this question, but for the life of me I can't remember what the response was. Where would I go, other than a junkyard, to find OEM replacement or aluminum upgraded Regulator Clips for an 88 TC?
"Failure is simply the opportunity to begin again, this time more intelligently" -Henry Ford
anasazi4st Offline
(02-08-2020, 07:25 PM)EricEaves Wrote: Hey guys! I'm pretty sure I already asked this question, but for the life of me I can't remember what the response was. Where would I go, other than a junkyard, to find OEM replacement or aluminum upgraded Regulator Clips for an 88 TC?
Not sure what you mean by Window Regulator Clips? Can you be more specific?
EricEaves Offline
The cheap brittle plastic clips that hold the glass in the track
EricEaves Offline
These
Attached Files Image(s)
347BIRD Offline
I USED A 2 PART EPOXY ON MINE AND DIDNT HAVE ANY ISSUES FOR OVER 10 YRS. 2 PART ADHESIVES CAN BE VERY STRONG
1988 Blk T-Bird, 5-spd, Raven int, 3G Alt, K&N conical, Boost controller, ported E6, ported and polished IHI @ 16 psi, 03 Cobra wheels, 255/40/17, 275/40/17, SN95 BBK lowering springs, SN95 Koni struts and shocks, Maximum Motorsports C/C plates, SN95 BMR tubular A-arms, Aluminum driveshaft, LED's, 255 LPH
fred k Offline
(02-12-2020, 06:54 PM)EricEaves Wrote: These
Years ago I went to an auto glass store and they sold me a tube of their adhesive.  Put it on the clips and never had a problem after that and used the leftover tube to repair the review mirror when it fell off.
I had tried 2 part epoxy but when summer came and it got hot, failure.
fred l kennedy
EricEaves Offline
I'm not looking for the adhesive, I'm looking for the clips outright. The current ones are broken. I think I managed to find aluminum replacements. Anyone seen or used these?
BJL Offline
Moderator
i havent installed them. but these are the ones i have, referred by others in the Group.
https://www.ebay.com/itm/Equalizer-MD128...1880968181
Brian Larkin
88TC 330,000 miles
Slightly Modified
EricEaves Offline
Awesome, that's the info I needed. Thanks!
