Window clip repair completed....
Kuch Offline
My pass side window clips broke last fall and I finally got to repairing them this week after driving around all summer with no pass window open. I read the write up on here on the process and I tore into it expecting to remove the window to fix it. Once I got the panel off and could see inside I realized that I could do it without removing the window. I could reach both areas where the clips are epoxied to the window to clean and sand the glass. It was tight getting to the front clip, but doable. All told it took me maybe 3 hours to complete and now I have an operating window again. One thing to note, the clips recommended work well and are solid aluminum, but I thought they fit to the window a little loose. I put them in the vise to squeeze them down a little to fit snug on the glass.
spittinfire Offline
What aluminum clips are you talking about?
Kuch Offline
I used these clips found here https://equalizer.com/universal-bottom-c...s-set-of-2
spittinfire Offline
OK. The factory ones are plastic. I just took them out, drilled 3 holes in them to allow for the adhesive to grab a little more and put it back together. I used 3M window weld to glue them, strong stuff.
matiii1 Offline
I did mine pass window about 3 months ago and I used those same aluminum clips with JB Weld and knock on wood they are still holding. I think the hardest part was getting the door panel and arm rest back together with out breaking too much,everything plastic is very brittle from age.Hope I dont need to take it apart ever again.
