Will Cougar door glass work in a TC?
verge Offline
I found a couple of mid to late 80s Cougars with power windows. The door windows look like the same size. Will the bolt-in glass and mechanism work in a TC?
Got a good deal on it, but maybe I should have saved a little longer!
Jackie Francisco
88 TC A4LD all options except leather, 2 1/2 inch Dynomax Super Turbo side exit exhaust, ported head, ported lower, gutted upper, "Home Depot" boost pressure regulator, NGK Vpower plugs, Walbro fuel pump.
If it aint broke, you aren't trying hard enough!
Dedpedal Offline
From a window tinters viewpoint, the door glass is slightly different so I would say it wont work. I could be wrong tho, it has happened once in my life.
87 Turbo Coupe
Ultimate weight reduction. A 93 Mustang coupe body.
TurboCoupe50 Offline
The '83-'86 Cougar/T-bird door glasses are the same. There are two seperate types though, with and without vent glass(do not interchange with each other.
All '87-'88 Cougars/T-birds use the same door glass..
Three 1988 Turbo Coupes .....
yea one of em has a 5.0 And runs 13.1s......
uhhh make that [email protected] with a 90hp shot of nitrous.
1988 Turbo Coupe331 AOD
1972 Comet GT
verge Offline
I read somewhere that someone used the bolt in glass in their 87/88, so I am assuming that it came from an 83-86 model.
Is this correct?
Jackie Francisco
