will a later Ford CD player 'plug-n-play' ?
86 XR7 5spd Offline
my 86 XR7 has an aftermarket radio which I would like to replace with a Ford unit
I realize in 86 that he TOP option would've been some kind of cassette player
I wonder if I can get a later Ford in-dash CD player that will plug-n-play ... i.e. use the same Ford plug and fit correctly in the 86 dash
David T
2.5" exhaust w/ cherry bomb
30+ mpg! 8.2 0-60, 16.4@88 1/4 (gTech)
gmaibach Offline
that type connector is used through 84-03 so you shouldnt have a problem connecting it but gettind a newer radio to fit in the dash
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
gmaibach Offline
i was also thinking... y wouldnt you just keep the aftermarket one because it sounds better and puts out more power
tr_guy79 Offline
I was going to go the same route, as I want to keep things looking stock. Ended up putting a kenwood in that I had laying round though.
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
86 XR7 5spd Offline
Smile
David T
