Hello guys it's me again, lol, well finally got a wideband it's a Innovate MTXL plus, I'm in need of help to install it, I need to know where does the yellow wire goes, the ECU? and what wire? or if it goes somewhere else?
Kuch
Sep 2016
Manlius, NY USA
did the instruction sheet come with it? If not, you should be able to go to their website and get the install instructions.
Yes it did Kuch!, I can install it the only thing that I don't know is where to plug it so it can send signal to the ecu.
Kuch
Sep 2016
Manlius, NY USA
03-22-2021, 02:55 PM
(This post was last modified: 03-22-2021, 02:57 PM by Kuch.)
Gotcha, I believe it is pin 29 at the ECU that is used for the factory sensor. Are you hooking up a PIMPx or something?
No I don't have Pimp or any other stand alone ecu, can it b connected to the stock?
Every WBO2 I have seen in the last few years has a narrow band O2 emulator output (0 to 1 V) that you can use as an input to the stock PCM that is looking for a narrow band signal. Without digging out my wiring diagrams I am pretty sure Kuch is correct that pin 29 is the stock narrow band O2 input to the TC EEC IV series of PCMs (LA, LA2, LA3, 8UA, etc). If the wire you are talking about is the NBO2 emulator output, connect it to pin 29.
Thanks Jeff!!,, I'm clueless and a bit confused..lol..the mtxl-plus has 4 wires,red,black,white and yellow. The yellow one goes to the ecu,i just didn't know where to tap it
Kuch
Sep 2016
Manlius, NY USA
If you are simply running the wideband as a standalone gauge to monitor your AFR, then simply leave it disconnected, tape it off and tuck it out of the way. I have an autometer wideband and it also has a similar wire as your innovate, I never connected it and don't need it until I hook up my PIMPx this summer.
^^^ Agreed. I still run the stock LA3 and just use my Innovate wideband to monitor the A/F ratio. The wideband really helped in tuning my home made meth injection system. I just securely taped the narrow band emulator wire out of the way.
Thank you guys I really appreciate it!!, got the gauge hooked up now
