Innovative LM1, LM2, LC-1
The LC1 is a stand alone controller that doesn't "internally" datalog and either can be bought alone or bought with a gauge(XD16 package). The LM1 and LM2 data log internally(no laptop required) and other neato stuff that you may not use. They also can be purcahsed with the XD16 package(the XD16 being the gauge only).
AEM UEGO setup is the cheapest setup, not that its the worst, but it may have some disadvantage because you can't "free air" calibrate the oxygen sensor AFAIK that may be a problem when you start getting false readings.
PLX has a few units, don't really have much info on them since I didn't reasearch them myself, but they are decently priced as well.
Autometer recently came out with a setup but have no clue on it either.
All of these systems all use the same sensor, and remember you
cannot use a sensor without a proper system. Most of the gauges don't hook directly to the sensor, the AEM UEGO does, but the XD16 system uses the LC-1 or the LM1/2, and same goes for the PLX which uses its own little controller box.
Quote:Originally posted by boosted chicken:
I think you can get them off the bay for around 260 bucks.
Sometimes cheaper, think i've seen them for $199-220
