Guys! I am frustraeted! I pulled some springs off a Tbird that look like aftermarket lowering springs. One problem. The car is up on jy blocks, so I can't even judge if they are lowering springs. Let me describe them to you. The are bright red and seem to have come that way beacause they are completely that color. They are the same in length as stock springs on the side by side test, but they are slightly thicker than stock and the coils are farther apart than stock. For example on the stock springs the last two coils are close together, but these springs are all the same in length apart. They seem to have exacly the same amount of ciols as well.I only found numbers stamped on the springs. They were ?4?5 806111. The question marks are where some of the numbers were not readable. Please tell me who these are made by!! Please
