COOKER
Jan 2002
Canton, Ohio USA
Hey guy's I think that I have a problem.
every time I down shift from 4th- 3rd and 3rd - 2nd then come to a stop there is a cloud of white smoke that rolls over the car. what could this mean. it smells bad like burnt oil or something...please help
DAVE COOK
NEED MY TC BACK
Does the car smoke out the tailpipes when first started cold? Does if smoke when you first give it gas from a stop? It sounds like you could have bad valve seals and/or worn intake valve guides. If it's antifreeze burning it will have a sweet smell, noticably different from burning oil.
[This message has been edited by Pete D (edited 05-19-2002).]
COOKER
Jan 2002
Canton, Ohio USA
Well I have a new refurbished head, so I don't think it could be that. I also have a code of 42 and I am thinking thatcould have something to do with it???????????
DAVE COOK
NEED MY TC BACK
segfaultxr7
Aug 2001
Cape Coral, FL
A Code 42 could most definitely cause that problem--it means you're running too rich. White smoke can be from unburned gasoline. I'd start by checking the fuel pressure regulator, if its vacuum line smells like gas then it's bad. The O2 sensor could also be suspect, but generally they cause a lean code (41) and would not screw things up so much that it would be spewing out unburned gas.
88 TC 5-speed
COOKER
Jan 2002
Canton, Ohio USA
well I just replaced the fpr and cleared the codes and it was fine, it smells like unburnt gas it seem like if i let it run in the morning to warm up it seems like it never warms up,the engine will but it will still have white smoke no matter how long it sits. please help could there be anything else.
DAVE COOK
NEED MY TC BACK
segfaultxr7
Aug 2001
Cape Coral, FL
Hmm.. So you mean replacing the FPR helped and got rid of the code 42, but it's still rich at idle? Running cold would do this. About where does the temp gauge sit? Our gauges are quite inaccurate and vary from car to car, but it should be somewhere in the lower portion of the normal range. If you drive it hard to get it running warmer and then idle, does it still blow white smoke?
Try pulling the sparkplugs, if they are very clean then you might be burning antifreeze. If they're black and sooty, that's another good sign that it's running rich. Good luck..
88 TC 5-speed
