(This post was last modified: 10-26-2023, 01:26 AM by anasazi4st.)
I have a question about the correct Motorcraft starter solenoid/switch for my 1987 Turbo Coupe.
I hesitate to use the word “solenoid” as technically that is the small device that typically sits on top of the starter and engages the starter pinion gear with the flywheel—what I need information on is the small round relay that is mounted on the left front fender within the engine compartment. This connects the battery to the starter and causes it to crank the engine—it’s technically a “switch” or starter relay.
I recently had one “go rogue” on me (this would be the second time in a few years) and refuse to disengage the starter from the flywheel. This was—as before—a NAPA one. Yeah, you might think, “Well Forrest, if it happened before perhaps you should stay away from that supplier”, right? I didn’t think it could happen again—what are the odds, right? Guess again.
So, looking at the Motorcraft options, I see one that has the four terminals (including the never-used “I” terminal)—WO133-1698717-MTR, for a 1987 Turbo Coupe, with VIN letter W…and one that has just three, which makes more sense to me. This one is F5TU-11450-BA (or also E9TZ-11450-B)—also known as SW-1951-C. According to the Amazon listing, this last one will NOT fit a 1987 TC, again with VIN “W”. It says it’s for a 1988 TC with VIN letter “T”.
It’s not just the Amazon listing that says that.
Why? Or, more precisely, why is it incompatible with a 1987?
Is it a voltage/current issue? Aren’t the two model years essentially the same?
I am most curious as to what this is about.
