Which rear main seal
mmedic50 Offline
I am dealing with a remanufactured engine in an '87 TC w/auto trans. I need to have the oil pan gasket and rear main seal replaced. I have located an oil pan gasket, but the parts guy at Ford says he needs the build date before he knows which rear main seal I need. Since this is a reman. engine it is very probable that it will not be of the same build date as the car that it is in. He says that the older part # is a 2 peice seal and the newer # (E5ZZ-6701-A)is a one peice seal. Any suggestion on which one I should get?
1988 TC 5 speed, Dark Blue
Build date 5/88.
140 mph Ford Motorsport Speedometer
Tripminder
Walbro 255 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
K&N Air Filter
Gillis Boost Control Valve
New rebuild- .030 over pistons.
SS valves(1.89/1.59).
Center Force Stage II clutch.
ARP head studs.
Crane roller cam .450 lift.
Gutted upper and ported lower intake.
Ceramic coated and ported E6 exhaust.
I can't find any notes on what year they made the change. You could order both and return the one you don't need. Or wait until you pull it apart and then order.
mmedic50 Offline
Is the 2 piece seal replacable with the 1 piece? Or are the engines actually different models that take different seals?
Build date 5/88.
Tripminder
K&N Air Filter
ARP head studs.
