Which ignition coils do you guys run
Keith Nubel Offline
I'm curious as to which ignition coil everyone uses and what works best.
85.5 TC 5 speed, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount Motorsport intercooler & sport grille, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo,Motorsport lowering springs, under restoration
1985 TC
I'm running an MSD Blaster coil. I never had a problem with the stock unit. Sis you see the picture I put up in your other thread. If that is th eright part and you want a spare, I'll send it to you.
MSD blaster coil here too.... the one that is a direct bolt in. Never had any problems with it, but didnt really notice any difference in performance over the stock coil.
Joe F Offline
MSD Blaster SS coil, driving Magnecor 10mm wires, driven by an MSD-6AL ignition system.
Joey likes it [Image: biggrin.gif]
Be Cool,
Joe
JR's Place - My 87 TC
[This message has been edited by JoeCool (edited 10-13-2004).]
Keith Nubel Offline
What's the advantage of the MDS over stock? Is it the cost?
1985 TC
I think it pack a little more power than stock. When combined with the 6AL, it gives you 3 sparks instead of just one, below 3000 rpms.
Lx-tasy Offline
I just put in an MSD coil, the bolt in one.I also put in a MSD Digital 6 ignition and the SDS will be going in this week-end.
Chris
Glenn 88TC Offline
Right now the stock one but the MSD will be going back in soon. No difference in performance but can't justify paying for something and not using it.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
Qwertys Offline
what about fuel efficiency?
'85 TC BPV and Ford FMIC
Ryan Offline
i put a blaster in my 83. didn't notice any change except an annoying buzz from it. does anyone else have this prob? is there a solution?
83- charcole/raven TC all options, except moon roof? my first love. in great condition, but needs a turbo and some TLC.
88- white on red. lots of miles. not as pretty but it gets me around and i love it too
