I am the lucky winner of a heater core change =(. I was just wondering, I am going to remove my A/C. Does Ford make a heater core without the attachments for the A/C lines? If they don't should I cap off the ends of the heater core, where the A/C lines are supposed to go? This is for an 88 Turbo Coupe.
Thanks
Thanks
88 TC
HY 35, Ported Oval head w/OS valves, EEC Tuner, Bob's MOAL, .510 lift cam, Tial 38mm wastegate, K&N in fender, Kirban AFPR, Walbro 255lph fuel pump, 57 lb inj., GN intercooler, Gillis valve, Race eng. adjustable cam pulley, HKS SSQV BOV, Steeda Tri-ax shifter, 4" DP to 2 1/2" exhaust, no muffers, Timing set to 12* BTDC, 26 psi of boost. Needs to get tuned!
Proud to be a NATO member!
