Which ECT sensor do I use? Rockauto shows two..
ianbfromct Offline
MOTORCRAFT Part # SW925 {#D2ZF10884AA, DOZZ10884A}
MOTORCRAFT Part # DY1145 {#DY681, F2AF12A648AA, F2AZ12A648A} For vehicle with rectangular connector, includes pigtail for splicing if vehicle has round connector
E1AF-12A648-AA, E4AF-12A648-AA
Thanks everyone
88 5 speed TC
jmthunderbirdturbo Offline
SW925, the motorcraft one.
EDIT-ALL OF THE FOLLOWING IS WRONG...SORRY[[[the other will work, but its a universal unit designed to work with multiple years/makes/models. the motorcraft one is a vehicle specific part.]]]
SEE MY NEXT POST. THANKS.
HTH
-J0N
ianbfromct Offline
Got it thanks ordered that guy and gonna see if it helps my cold idle issue.
88 5 speed TC
ianbfromct Offline
Actually I made a mistake the one I need is for the ecu to read the coolant temps it goes in the lower intake between the 2nd and 3rd cylinder. The SW925 is for the gauge itself.
88 5 speed TC
Oh, i see. then yes, you needed this one:
MOTORCRAFT Part # DY1145 {#DY681, F2AF12A648AA, F2AZ12A648A} For vehicle with rectangular connector, includes pigtail for splicing if vehicle has round connector.
i was confused as well, ignore my original post. sorry.
-J0N
ianbfromct Offline
So it's okay to change the harness connector ? I thought it was odd wasn't sure why they changed the plug design. I was trying to find the round one but if this is all there is out there than it I'll have to do.
88 5 speed TC
Not B Anymore Offline
http://m.advanceautoparts.com/mt/shop.ad...ure+sensor
This is the one I've been using for the past four years without issue.
from the looks of the picture, i dont think youll have to change anything. they may have worded that incorrectly, and include the round connector for those who have the square. the round is far more common on that era of FORD, and looking at the list of applicable vehicle, im pretty sure all but one is a round plug harness.
you could also just grab the napa or advance auto supplied part, but i have had less luck than B with parts store electronics. i have yet to meet a pickier engine when it comes to sensors and other electronics, (save for 80's and 90's alfas... Big Grin ) so i try to keep it to motorcraft when possible.
-J0N
