which compression tester do you use?
Thndrchckn420 Offline
I borrowed a comp. tester from a buddy of mine and it has both spark plug threads, but the smaller one doesnt have long enough threads to screw into the head. What do you guys use? Thanks
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
I use a screw in kind. The kind with the rubber cone on the end where you just press it to the spark plug hole are a total waste
The kind Im borrowing is Actron brand. It screws in, but the adapter for the smaller plug only has about 3/8" of threads on it, so it doesnt catch the threads in the head.
Kev Offline
I got mine from Wal-Mart for around $22 It had the two different spark plug type adapters and it works excellent. It looks like the brand on it is "IEC". The "IEC" has a bold line above it and a bold line below it. If this isn't the brand name, then I don't know what kind it is, or do I care. It just works.
Kev
1988 TC 5spd
Well I went to Walmart this morning, but they didnt have anything. Decided to go to NAPA to get a head gasket and bolts, and found a really nice compression tester. Its just store brand (NAPA), but it works great... It was around $35 and came with both plug adapters.
#1= 145psi.
#2= 147psi.
#3= 149psi.
#4= 150psi.
Whoooohooo!!
Ryan H Offline
I got a KD Tools compression tester from my local NAPA. I dropped it and it broke and they replaced it... it has a lifetime warranty. Smile
trashline Offline
napa quality is usually pretty good with things like that. Hense the higher prices, but those numbers doo look good all with a couple of each other.
Brian
www.BCPCustom.com
06 Cobalt SS
BogusSVO Offline
I have a Matco one I bought about 13 years ago still works great,
just chect my compression with it today
#1=160
#2=163
#3=160
#4=165
and the plugs were a nice tan still
Owns more Turbo FORDS than the law should allow....and still getting more
85 TC going under the knife
84 Turbo ranger --($800.00 ebay) Redneck work truck
shays88tc Offline
i bought one from fleet farm..can't remember the brand name but it worked great. it had the exact right size of screw in adaptor for the 2.3t i agree the push in ones are junk
Completion Date: Quarter to never..
ipsd Offline
I've got an Equis brand screw in style. Wroks everytime and I've had it for years.
