jtmbristol
Jan 2004
S.E. michigan
So I tried the search function and get 500 returns everytime, whats up with that ?
Looking for an OEM, exact fit replacement radiator. I see radiators listed on Rockauto, Napa, Advance etc but reading reviews none are exact fit and require mods to make them work.
Any help would be greatly appreciated :-)
88 'Bird, 5spd, .63 T-3, ported E6, 3" into dual 2 1/2 exhaust, 1.89/1.59 valves with Boport 1.5 cam, Ram Powergrip clutch, stock IC.
Tbird-fanatic
Oct 2011
Hazel Green, WI
Just get one for a fox mustang. Same exact thing. I tend to get one for a v8, I like the cooling of the bigger one.
turbird77
Apr 2013
Monroe, NC
Spectra Premium part #CU138 is about as close to an exact replacement for the stock radiator as your gonna get from the aftermarket. I had one in my TC for awhile, and it does fit almost just like the original. The DS upper rad mount rubber bushing needs to be modified slightly, for it to mount securely like the original though.
88 TC - Work in Progress.
boosted chicken
Jan 2006
Odessa, Texas
I use the Autozone one for a fox Mustang. Lightweight aluminum and cools great. Like 77 said, just a little trimming of the upper rubber bushing...no big deal.
I have one that is out of my low mile car , looks like new . Its OEM . let me know . best to e-mail . [email protected]
DW
amar67
May 2013
Atlanta, GA
I just installed a Spectra A556 (CU556) from Autozone a couple of months ago. No modifications needed at all. It slipped right in with no issues.
$85.99 - lifetime warranty.
http://www.autozone.com/autozone/parts/S...3456_4648_
1987 Thunderbird Turbo Coupe - 5 Speed Manual
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
is there a reason why you wouldn't want to use a newer, better designed high efficiency aluminum radiator?
1988 TC 2.3/5-Speed, 148K
jtmbristol
Jan 2004
S.E. michigan
Of course I would rather have a better radiator than a 25 yr old one....just had read many horror stories of fitment/modification problems.
Thanks for all the replys and info !
I put Summitt brand Mustang 2 core (1" cores) Aluminum rads in both my Tbirds. Bracket modding took all of half an hour per car.
jtmbristol
Jan 2004
S.E. michigan
Got the CU556 from O'Reilly's, even found a $15 off coupon online :-) Dropped right in, just had to make new thinner rubber for under the top brackets.
Thanks for all the help !
