driverlarrytc
Jan 2006
Hagerstown, MD
I just installed the engine. I have a big valve head,t3/t4 hybrid 50trim, 3" down pipe, afpr, and factory pump for now. Just wandering whether I should start at the factory setting.
Ryan H
Oct 2004
Panama City, FL
I'd start at around 42 base to be safe. I have mine at 41 running 18 PSI on the stock IHI. You REALLY need to get a better pump in there before you do any high boost. (unless you like replacing head gaskets, pistons, valves, etc.)
driverlarrytc
Jan 2006
Hagerstown, MD
I am planning to replace the pump after the engine is broke in and the tank is empty.
Thanks for the help.
I'd recommend limiting boost also until the pump upgrade is in place and you get a few hundred miles on the engine.
driverlarrytc
Jan 2006
Hagerstown, MD
That was my plan. I can use the factory pump as an excuse to keep my foot out of the throttle until a few hundred miles.
tps87turbo
Feb 2003
Hammonton, NJ USA
Turn the boost down to 7-8 lbs until you change the fuel pump. Its far too easy to mash the pedal while doing some spirted driving on a nice sunny day.
Import Killer
Aug 2001
Lincoln, DE USA
Make sure after a few hundred miles you rev it to about 3500 or 4K and then let off the gas and create some vacuum to set the rings.
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
MOMO shift knob and boot
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
driverlarrytc
Jan 2006
Hagerstown, MD
Racing since I was five doesnt help the right foot stay off the gas pedal. That is why on thursday I will have the boost turned way back. I cant wait to romp on it though, but I want to make sure everything is right first.
Thanks everyone for the assistance.
