HOODBIRD
Mar 2008
WASHINGTON, DC
Hello,
Today i was working on my horn wire and found 2 other wires cut clean. Hanging from the wire harness from which the horn wire comes from. One wire was black the other looked to be black and white. I do not see anywhere of where they could go. Just wana make sure they don't go anywhere special that may screw a system up in the car.
Left front fender where header meets fender.
86 TC
Thanks
Dave
86tc 5speed k&n, gfb boost controller, autometer gauges, tripminder, fmic, and upgrading as fast as possible
Protouring442
Jun 2009
Lenoir City, TN
I answered over on Foxbody, but in case you don't check there in a while... those are the wires for cornering lamps. When I had the dash out of both my car (which does not have cornering lamps) and my parts car (which did have them), it looked like everything was there except for the lamps and sockets. I'm guessing you can just add the lamps and sockets and have cornering lamps that work.
Shiny Side Up!
Bill
Wait, where does this go?
HOODBIRD
Mar 2008
WASHINGTON, DC
Ok cool thanks alot
BJL
Williamstown, New Jersey
you will also need the thermal relays to make them work
Brian Larkin
88TC 330,000 miles
Slightly Modified
Protouring442
Jun 2009
Lenoir City, TN
Where might these be located? Under my dash I found a black box marked cornering lamps, yet my car was not equipped with them. Is this where these are located?
Shiny Side Up!
Bill
BJL
the relays look like two turn signal flasers but 4 pin.. located on the dash near the tranny tunnel drivers side along with the other relays for the autolamp.....
Brian Larkin
88TC 330,000 miles
Slightly Modified
