i want to get my 88 turbocoupe head ported while the engine is apart, who does good work? how much should i expect it to be with a 3 angle, port, polish, and some bigger valves? thanks.. can anyone on here do some good port work for a fair price?
~ITaliano~
88 Whtie turbocoupe on Raven,All opitons minus leather, and keyless, 5 speed, K&n frount mounted, boosted to 18psi, new paint, clutch,White faced gagues, Custom painted interior trim pieces (change from blue to charcol to blackish purple kinda color)Premier dep730R headunit, 2 12" jbl Comp' intercooled subs in box, 3 amps, Lowered 1 inch, AM lunar boost, air fuel, tach, mustang pod, Countless other mods.. look ok Tim Jones  hehe
sctur601
Apache Junction, AZ,usa
I can do OK portwork, and can have everything else you said done at a good local machine shop.
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
And it still feels slow!
Thanks
Shawn
Please click the link if you want to sign my aftermarket head list
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
I also do port work, if you need something ported email me at [email protected]
Wags88TC
Las Vegas
Be careful who does the machining! Guys that work at machine shops treat our heads like it's a bowtie head - I know a guy that had 2 heads ruined by "good" shops. once too much metal is removed, it's too late!
Steve Wagner
Nato member
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR, 3" exhaust from turbo to tip (high flow cat/ Dynomax Superflo muffler), A-pillar gauges(A/F & Boost), 16" Prime 5 spoke wheels(245/45ZR16 Bridgestones). Workin' on the front mount IC and some exterior mods
Steve Wagner
Nato member
84 SVO
Steves right. Find a shop that does 2.3 work for the roundy round guys. At least they will be familiar with the head.
Sctur601, nice pocket work
sctur601
Yes you need to have good machine work done! The guy that is at my favorite machine shop races 2.3s he is very good. I have been trading portwork for valvejobs with him for a while. The key to a good valve job on these engine is make sure you have tight valve guides before they but the cutter/grinder to it. Might as well have hardend seats put in also, less of a chance for the head to crack (if your lucky and its not cracked now).
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
