07-11-2013, 06:39 PM
(This post was last modified: 07-11-2013, 06:39 PM by ianbfromct.)
Hey all im a noob with anything electrical but have installed tons of car stereos and what not. I have a simple question..I ordered a eletric auto metere oil pressure gauge with the sending unit. Now I plan on down the road in the next few weeks depending on my finances will order at least a wideband and possibly boost gauge or fuel pressure. Now since I know ill be ordering a few more gauges that will need a 12 volt feed and also a feed for the back lights on the gauges when I put on my lights. Should I wire up some kind of power block or something? Not sure how its done properly and I dont wanna jimmy rig the wiring. Can I run 12 volts to one gauge and run that 12 volts to the other 2 gauges in the same pod?
88 5 speed TC
Stang8u
Dec 2012
Apple valley CA
To answer the last part yes
:mad:
You can run one ground, one hot and one dimmer and connect all your gauges to them.
Viper
88 TC Project Car|Deep Ocean Blue Metallic|Marchal Fog Lights|Custom Interior|Custom Instrument Panel|Gillis Valve|Cone Air Filter
Shine she may, Run she must
Viper7 Wrote:You can run one ground, one hot and one dimmer and connect all your gauges to them.
Dumb question where should I grab the dimmer wire from ??
88 5 speed TC
Stang8u
Dec 2012
Apple valley CA
You tap into the dimmer swich or if you don't care to have them dim just tap into the headlight fuse
:mad:
powerstrokin
Jun 2013
Beautiful Southern Indiana
This is why I used ISSPRO gauges in my last Powerstroke. The connectors on the back of the gauges make it super easy to "daisy chain" multiple gauges.
For anyone looking at adding gauges, I would highly recommend ISSPRO. Quality stuff. You pay for it, but it's worth it. (No, I don't work for them!) I had the EV2 series stuff in my truck and they were nice.
'88 Turbo Coupe
