351C T-Bird
Jul 2003
Dix, Illinois, USA
what is the widest wheel/tire that will fit under the rear of my 87 turbocoupe with little or no modification?
"I rarely know what you're talking about." -Homestar
ThunderChickenTC
May 2003
Cincinnati, OH
i'm not positive myself, but if you don't get much feed back, try the local tire shops and ask them that same question and they could most likely answer that for ya. keep in mind that the suspension will play a role in how high the tire can be, ..the worse your suspension, the closer it is to the tire. Please let me know this when you find out, cause i am sorta curious myself now that you asked that.
Thanks, Dennis a.k.a.ThunderChicken
88 TC ....Custom window tint, American Racing 15" rims with Michelin X-radial tires 215-70-r15, 9mm Ford Racing Spark-plug wires, K&N air filter, 3 core radiator, 180* Thermostat, Head completely rebuilt with an upgrade to a roller-cam, Silvannia Silverstar Bulbs for headlights, Painted wiper blades, XM Radio, Custom system with a custom built 5 cu. ft. box(2 and 1/2 cu. ft. per sub.), Custom Alarm System. Next is Magnaflow exhaust mod!!!
Glenn 88TC
Lebanon, PA
I have 15X8(5.5" BS) Weld Draglites with 26X11.5 Et Streets. I will be gewtting 15X10's at some point and will be going bigger with the rear tires.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
Hybridbird
Aug 2001
Rockford IL
I have 17x9's on the rear of my 88 with 275/40/17's on itand only had to roll the inner lip of the wheel opening,of course mine is lowered I would sau atleast an inch also.Only when I have a lot of weight (kids) in the back and bottom out at high speed does it ever rub,and even then just a little bit.
"Finch....get the f*ck away from that fikas......that is a jizz-free fikas!"
351C T-Bird
Jul 2003
Dix, Illinois, USA
Hybridbird, any chance you could post pictures of your car? i'm considering going with very much the same setup as you described and i'd like to see how yours looks.
