Wheel beaings and seals
RC Martin Offline
I had a lot of issues tracking down the right parts recently for my 84TC. I got the correct rotors and two of the right bearings but the inner bearing and seals were the wrong size.
The correct ones:
Bearing seal - Timken 6815
Inner bearing - Timken SET17
Outer bearing - SKF BR12
The INCORRECT parts listed at Rockauto, Oreilly, etc.:
Bearing seal - part 19223
Inner bearing - SKF BR5
Not B Anymore Offline
EVERYBODY lists the wrong inner bearing and seal. I haven't a clue as to why. I found this out myself a while back, but never took the time to find out the correct parts. Thanks for posting this!
Just wanted to add something...
The correct part numbers you came up with are listed for all '83-'86 Thunderbirds EXCEPT TurboCoupes. So if you're looking to get a set and can't remember the part numbers, you can just ask for the inner bearings and seals for an '83-'86 Base Model, Elan, or Sport and you will get the correct parts.
