Hey all, have 88 TC, working on pulling the a4ld b/c of fluid leak. I noticed that the bolts that mount the drive shaft to the rear axle are external torx head? Can anyone tell me what socket to buy for these??
Thanks a million.
Russ
M12 x 1.75 - 26mm long. Head is stamped. Need to use a 12mm, 12 point socket
Thanks so much sir!
Whats the best way to get to the dipstick tube mounting bolt (from above or below)?
Either way, its a PITA. I access it from the top.
Ditto what Jeff said
Snap on makes a special socket/ extension specific for the removal of ford drive shafts. Its a dream come true!!!
Zero
1987 Turbo Coupe Auto- gone
1991 Sport 5.0 Auto- gone
1996 LX 5.0 5spd- Gone
1989 Super Coupe 5spd- gone
1984 Turbo Coupe 5spd- newest project
Not B Anymore
Nokesville, VA, USA
I just use a regular wrench :dunno:
turbobike
Sep 2006
northern Ohio
Sometimes loctite can be pita on the flange bolts. I bought a Snapon 12m 12 point 3/8 swivel impact socket. With an impact gun you can have those bolts out in no time.
85 TC,86 TC,65 Mustang GT
^^^^ +1 on that, Mike. I use a regular 12 pt socket with an impact rated U jount and my 750 ftlb impact wrench. The bolts come out easy, and I havent broken the non impact rated socket yet.
TurboCoupe50
Chesapeake, Va
B Wrote:I just use a regular wrench :dunno:
Same here...
If you insert another boxed wrench into the open end of the 12mm you'll have more leverage to break bolts loose or re-tighten...
