What should I do for my exhaust
88LemonCoupe Offline
Hey everyone quite recently I revved my engine with the stock exhaust system and I guess one of the pipes detached from the DP section, so it's basically running straight piped. I am wanting to do some cheaper exhaust mod and was wondering what you guys think I should do?
Get a 3" DP and just run it to a turn down? and get rid of the rear exhaust setup? get it fixed and gut the cats and put on higher flow muffles (SuperTurbos) or what?
bump
THere are hundreds of good "what exhaust" posts... do a search!!!!!!
slacken00 Offline
stinger, cheap and easy
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
Aaron Offline
I went with the Stinger 3" downpipe and passenger side exhaust, coupled with a Dynomax bullet and a turndown by the rear axle. Very nice sound, if a bit loud, and simple, and relatively cheap.
Aaron
1987 TC:
T3/T4 Turbo, 40Bob Header, TiAL 38mm Wastegate, SPEC Stage 3 Clutch/Aluminum Flywheel, 3" Stinger Elbow Exhaust dump, Gutted/Polished upper, ported lower, Walbro 255HP fuel pump, Kirban AFPR, ROH Snypers w/ M/T Drag Radials, Corbeau FX1 Seats, Large NPR, Forge RS BOV, 3G Alternator, MS, 75# injectors, EDIS
http://www.cardomain.com/ride/2270259/1
Here is what my muffler currrently looks like, I'm going to a few exhaust shops tomrrow.
http://img.photobucket.com/albums/v187/S...G_0599.jpg
http://img.photobucket.com/albums/v187/S...G_0600.jpg
http://img.photobucket.com/albums/v187/S...G_0597.jpg
What options do you think I have? Would I just have to replace the muffler and a section of pipe to return it to stock If that is what my wallet dictates? Or do you think I'd have to do a more severe repair job.
For performance/budget wise what do you recommend I do from this list:
3" DP
Bigger pipes all around
New Muffler (guaranteed)
Highflow Cat
Muffler placed backwards
Other
Quote:For performance/budget wise what do you recommend I do from this list:
Stock replacement is going to be the cheapest but gives no performance improvement.
If you want a solid performance increase you are going to have to do most of the stuff on your list.
However you are going to have to educate me as to what putting a muffler on backwards does? Thats a new one on me
The backwards muffler wouldn't increase performance my bad... It is actually referred to as a resonator http://en.wikipedia.org/wiki/Resonator#Automobiles
