Ok for the last day or two my "ABS" and "Brake" lights have been staying on all the time. Today, I left work for my lunch break and the brakes were fine. When I came back out to my car the pedal was rock hard and I had to stand on it just to get the car to slow down (good thing I didn't have far to go). When I left work, the brakes were fine all the way home until I had to slow down to go through a small town, and the pedal got rock hard again. A little ways up the road I was putting on the brakes just seeing what it would do, and it all of a sudden went from being very stiff to normal. It did this a couple times and then it was fine the rest of the way home. Is my master cylinder on its way out or what?
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'87 Thunderbird Turbo Coupe
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
My Turbo Coupe
