What rpm for full boost
Redbone Offline
As some may or may not know, I'm still running the stock IHI. With my mods listed in my sig., I'm not getting full boost (18 psi) until almost 3k. Is this normal or should I be getting full boost sooner. I'm curious what other people are getting full boost at (especially with the IHI). On Stinger's website, I know he listed the IHI getting full boost as early as 1800 rpm with some airflow mods.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
goodstuff84 Offline
depends on the gear, when i had my IHI i didnt get full boost in 1st until around 3k. 2nd gear and up was just over 2k rpm
Justin
88 TC, E-bay 50 trim t3/t4, ported E6, Volvo FMIC, Forge BPV, walbro 255 HP pump, Kirban AFPR, RAM clutch, full 3" stinger single exhaust w/dynomax muffler & dumped at axle, K&N cone on the VAM, *13 base timing, boost @ 20psi. http://s661.photobucket.com/albums/uu337/Goodstuff84/
turbospoolin23 Offline
I'm still running my IHI and for the first 2 or 3 gears i don't get full boost (17~18psi) until about 3000 rpms. In forth and fifth i can get full boost a little sooner, but not by much, definitely not before about 2700rpm. I don't think my car even starts building boost until after 2000rpm in any gear. Last week i also seen on stingers website that he lists the IHI to get full boost at 1800rpm with some airflow mods, that's why i was testing mine.
Redbone Offline
You guys seem to be getting about what I got. I was starting to get ready to check for boost leaks. Thanks for the replies.
Goodstuff, how's your ebay turbo working out? I'm thinking about getting one.
John A.
xcrunnerbd Offline
I'm getting full boost with mine about the same in first as mentioned, but higher gears it's closer to 2k.
Shelf: .48 T3, ported E6, BPV
