what perfromance upgrades next
Ricky03 Offline
I have about 2k to spend on upgrades for my TC and don't know which way to go. I'm torn between a BO-Port head, Megasquirt engine management, or NO2. I have no experience in turning EFI computer systems so I'm not sure if the Megasquirt is over my head or not, even the one from Turbo-Dad on TF. I want to get about 350 HP out of my set up.
Please give me any suggestions.
Thanks,Ricky
gadgetolds Offline
Im no expert but I think your biggest gain out of the 3 would be the head. Assuming its basicly stock, and with everything else opened up in that system its the only restriction, along with maybe a 3" turbo elbow.
Pete D3 Offline
The head would probably be your biggest bang.
You have a T3 now. That and the stock injectors are going to peak out in the same HP range of 280 to 300. After that you are going to have to get a bigger turbo to get more HP and bigger injectors to feed it. That is when you will need an aftermarket management system. By then you would want the head ported anyhow, so do it early and enjoy it.
x
Tom Senior Offline
Banned
Call BO and have him build you a head. The HP is in the head and valve train. BO heads are awsum.
He will install seats that will prevent cracks and larger valves. His heads are not cheap but worth every penny. I dynowed one and the HP gain was tremendous over a stock head. Like night and day. Tom Senior. Smile
xcrunnerbd Offline
Another vote for the head, also stage 3 hybrid t3/t4 50 trim turbo, bob's log, 3" elbow, alky injection...
Shelf: .48 T3, ported E6, BPV
86XR7auto Offline
Moderator
The power is in the head....which applies with all engines. You can boost the heck out of it. Some people do that. And deal with all the problems lots of boost causes.
But a nice head will help you make more power at your currently level....but you are almost out of fuel now. A nice head is just going to make that worse. So after the nice head mod...you are going to have to learn about the more fuel.
Good luck,
Travis
boosted85 Offline
how much do these heads go for? or is there a website that tells u
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
I don't know if prices are posted but start here:
http://www.bo-port.com/
Ricky03 Offline
thanks guys, was leaning towards the head anyway. I noticed no said anything about NO2. Anyone using it on a mostly stock motor with good results?
xcrunnerbd Offline
There are a few using it, but not very many. Hopefully someone who is will chime in... have you tried searching on turboford? About all I know is that a "wet" system is the one to run and just enough to get the car going until the turbo takes over.
Alky injection can help a bit with fuel but Travis is right. Perhaps you should look into MS or something to allow larger injectors. Do you have a Wideband? Perhaps this is the time for one.
