What is the secret handshake?
1987tc Offline
There must be something that I am missing!
I want to remove the bolt in the distributer hold down to replace it with that Allen wrench set up that was sold online a while back. I can see the bolt looking through the serpentine belt but cannot get a socket on it!
I had been able to get to it on my other TCs but not this one. The hose for the PCV that runs down there is in the way.
Is there a secret handshake I need to know?
Wes
Blue88TC Offline
swivel and a extention works wonders for me on my 88!!!!
1988 turbo coupe, ported head, big valves, RW #1 cam, adj cam gear, front mount, ported intake, gillis, k&n cone, exhaust
1987tc Offline
I tried that. No dice.......... [Image: frown.gif]
Remove dist cap, which will give you a little bit more clearance. Might help to remove the PCV hose that is in the way.
B_Lieder Offline
I've used a 17mm crows foot and a 6 inch socket extension in the past.
Bill Lieder
1988 TC
MODS: Ported big valve head with ss valves, ported upper & lower intakes, Racer Walsh #2 Roller cam, Walboro 255HP pump, Kirban adjustable FPR, 3" Exhaust, Star stage 2 clutch w/ stage 3 pp, K&N cone, Gillis valve, Race engineering adjustable cam sproket, 245 50 16 Bridgestone tires
Bill L
Gregg Offline
Curse a lot!!! I always get it eventually after that. hehehe
Gregg
Quote:Is there a secret handshake I need to know?
If we told you we would have to kill you.
I forget, i put in the allen wrench set up a few months ago. I can tell you that you will really like it ---- when you get it in!! [Image: biggrin.gif]
1987tc Offline
I know I will like it! Right now the timing on the car is set at 10 btdc with the spout out. I would like to advance it a little to liven up the car a little.
Wes
Matt S Offline
I can get to the bolt quickly, with the car running and everything in place using 2 5" 3/8 extensions and a crows foot. There's an art to slipping the crows foot under the hose there, but after a few times it's easy for me now. The hard part is keeping it all together and not falling in hard to reach (and hot) places.
Duct tape. Is there anything it CAN'T do?
Sold it Sad*
Turbobob_dup1 Offline
Once you do get it out very quickly run to the nearest Jyard and grab a 13mm bolt from an N/A stang [Image: wink.gif]
To get it off you should be able to slip a shallow socket by the PVC hose and slowly lift the dist as you loosen the bolt. You won't have to take it all the way out. Just till the bolt is loose enough to take out by hand. Thenm get that 13mm bolt in there and your homefree [Image: biggrin.gif]
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in the fender,gutted upper/knife edge lower,big valve head,roller cam,60mm throttle body,Talon 1G BPV.
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
